We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Do you want a single screen? Still you need to simultaneously display content from different input sources? Great! The Iiyama B2875UHSU is exactly what you are looking for. Featuring 4K resolution, the monitor offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications from two different data sources. In addition, the high-quality panel offers high performance with great color reproduction and a fast response time, and the height adjustable stand allows you to adjust the screen position to your preferences. Powerful and useful - Iiyama B2875UHSU - your monitor for years to come.
Product Description | iiyama ProLite B2875UHSU-B1 - LED monitor - 28" | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class G | Energy Consumption per Year | 80 kWh | Power Consumption (On mode) | 33 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.16 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DVI, DisplayPort, VGA | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 100/240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 65.95 cm x 23 cm x 41.05 cm | Weight | 7.5 kg | Compliant Standards | VESA DPMS, TUV Bauart, VCCI Class B, VESA DDC 2 B | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 28" |
Panel Type | TN |
Vertical Refresh Rate | 30 - 75 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese |
Features | Picture in picture, picture by picture, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Black Tuner |
Colour | Black |
Weight | 7.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2.5 Watt |
Connectivity | |
Interfaces | VGA , DVI , USB , Headphones , DisplayPort , HDMI |
Mechanical | |
Tilt Angle | 17 |
Swivel Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x Mini DisplayPort cable - DisplayPort to DisplayPort , 1 x USB cable , 1 x audio cable |
Power | |
Input Voltage | AC 100/240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 33 kWh/1000h |
Power Consumption (Typical) | 44 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Apple MacOS, Microsoft Windows |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
