iiyama ProLite B2875UHSU-B1 28" 3860x2160 1ms VGA HDMI D...
iiyama ProLite B2875UHSU-B1 28" 3860x2160 1ms VGA HDMI DisplayPort LED Monitor
£355.09
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 4K resolution
  • Height adjustable stand
  • Blue light reducer
  • PIP function
  • Diagonal Size: 28in
  • Max Resolution: 3840 x 2160
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, DVI, VGA (HD-15)
Product codes
Do you want a single screen? Still you need to simultaneously display content from different input sources? Great! The Iiyama B2875UHSU is exactly what you are looking for. Featuring 4K resolution, the monitor offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications from two different data sources. In addition, the high-quality panel offers high performance with great color reproduction and a fast response time, and the height adjustable stand allows you to adjust the screen position to your preferences. Powerful and useful - Iiyama B2875UHSU - your monitor for years to come.
Product Description iiyama ProLite B2875UHSU-B1 - LED monitor - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class G
Energy Consumption per Year 80 kWh
Power Consumption (On mode) 33 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch 0.16 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 1 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort, VGA
Display Position Adjustments Height, swivel, tilt
Voltage AC 100/240 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 65.95 cm x 23 cm x 41.05 cm
Weight 7.5 kg
Compliant Standards VESA DPMS, TUV Bauart, VCCI Class B, VESA DDC 2 B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£355.09
