iiyama ProLite E1780SD 17" 1280x1024 DVI LCD Monitor
£113.67
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Equipped with two high quality stereo speakers
  • LED-backlit
  • Advanced Contrast Ratio (ACR)
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
The 17" ProLite E1780SD is a LED-backlit monitor with good response time, high contrast and sRGB and gamma correction functions that permit even the finest nuances of color to be set accurately.
Product Description iiyama ProLite E1780SD-B1 - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 37 cm x 17.8 cm x 37.95 cm
Weight 2.6 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards VESA DPMS, GOST-R, TUV Bauart, TCO Displays 6.0, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E1780SD...
£113.67
