iiyama ProLite E1980SD-B1 19" 1280x1024 5ms DVI-D VGA Bl...
iiyama ProLite E1980SD-B1 19" 1280x1024 5ms DVI-D VGA Black Monitor with Speakers
£116.49
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High quality stereo speaker
  • LED-backlit
  • Advanced Contrast Ratio
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £119.98
Save £1.50
The 19" ProLite E1980SD is a LED-backlit monitor with 5 ms response time, high contrast and sRGB and gamma correction functions that permit even the finest nuances of color to be set accurately.
Product Description iiyama ProLite E1980SD-B1 - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 41.1 cm x 18.95 cm x 40.2 cm
Weight 3.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E1980SD...
£116.49
