iiyama ProLite E2083HSD-1 19.5" 1600x900 5ms VGA DVI-D L...
iiyama ProLite E2083HSD-1 19.5" 1600x900 5ms VGA DVI-D LED LCD Black Monitor with Speakers
£94.04
Delivery:
Standard: 1-3 working days
Key features
  • A true ECO-friendly product
  • Advanced contrast ratio
  • Easily mount your monitor to a wall
  • High quality stereo speakers
  • Diagonal Size: 20in
  • Max Resolution: 1600 x 900
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
The ProLite E2083HSD is a 19.5" LED-backlit monitor with 1600 x 900 resolution. It features 5msec response time and more tan 5M: 1 advanced contrast ratio assuring vibrant images and blur free video. Analog VGA and digital DVI inputs ensure compatibility with the systems and associated graphics cards. The monitor is Energy Star qualified and VESA mount compatible.
Product Description iiyama ProLite E2083HSD-1 - LED monitor - 20"
Device Type LED-backlit LCD monitor - 20"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1600 x 900
Pixel Pitch 0.271 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 46.95 cm x 20.3 cm x 36 cm
Weight 2.7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS, DDC/CI, GOST-R, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E2083HS...
£94.04
