iiyama ProLite E2280WSD-B 22" 1680x1050 5ms VGA DVI-D Bl...
iiyama ProLite E2280WSD-B 22" 1680x1050 5ms VGA DVI-D Black Monitor with Speakers
Product codes
The ProLite E2280WSD is a 22" 1680 x 1050 LED-backlit monitor. It features 5 ms black-to-black response time and 5,000,000:1 advanced contrast ratio assuring very good picture quality. Analog and DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is TCO and ENERGY STAR certified. A reliable solution for both home and office use.
Product Description iiyama ProLite E2280WSD-1 - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 51.25 cm x 20.45 cm x 39.55 cm
Weight 3.6 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VESA DPMS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E2280WS...
