iiyama ProLite E2282HS-B1 22" 1920x1080 1ms VGA DVI HDMI...
iiyama ProLite E2282HS-B1 22" 1920x1080 1ms VGA DVI HDMI LED Monitor
£111.48
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full HD
  • Flicker-free + blue light
  • Speakers and headphones
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The ProLite E2282HS-B1 is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80 000 000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2282HS is equipped with two high quality stereo speakers. TCO Certified, this monitor is a reliable solution for both home and office use.
Product Description iiyama ProLite E2282HS-B1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 21.8 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating Matte
Colour Matte black
Dimensions (WxDxH) - with stand 50.5 cm x 19.3 cm x 38.2 cm
Weight 3 kg
Compliant Standards TUV GS, RoHS, WEEE, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E2282HS...
£111.48
