iiyama ProLite E2283HS 22" 1920x1080 1ms VGA HDMI Displa...
iiyama ProLite E2283HS 22" 1920x1080 1ms VGA HDMI DisplayPort LED Monitor
£104.42
44 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flicker free
  • OverDrive on/off
  • ACR
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite E2283HS is an excellent LED-backlit monitor with high resolution. It features fast response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with installed graphics cards and embedded notebook outputs. The E2283HS is also equipped with two high quality stereo speakers.
Product Description iiyama ProLite E2283HS-B3 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class B
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 21.8 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 50.5 cm x 19.3 cm x 38.25 cm
Weight 3 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, DDC-2B, VESA DPMS, VCCI Class B, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E2283HS...
£104.42
