iiyama ProLite E2482HS-B1 24" 1920x1080p 1ms HDMI VGA DV...
iiyama ProLite E2482HS-B1 24" 1920x1080p 1ms HDMI VGA DVI LED Monitor
£119.29
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full HD resolution
  • Flicker-free + blue light reduction
  • ACR (Advanced Contrast Ratio)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The ProLite E2482HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1 ms response time and 80.000.000:1 contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The E2482HS is also equipped with two high quality stereo speakers. TCO Certified, this monitor is a reliable solution for both home and office use.
Product Description iiyama ProLite E2482HS-B1 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 24.9 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.277 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Tilt
Screen Coating Matte
Colour Black
Dimensions (WxDxH) 56.55 cm x 20.3 cm x 41.2 cm
Weight 3.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, VCCI Class B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite E2482HS...
£119.29
