iiyama ProLite P2252HS-B1 22" 1920x1080 5ms HDMI DVI-D L...
iiyama ProLite P2252HS-B1 22" 1920x1080 5ms HDMI DVI-D LED Black Monitor with Speakers
£127.71
Delivery:
Standard: 1-3 working days
Key features
  • LED-backlit
  • ACR
  • HDMI
  • VESA
  • FULL HD
  • Speakers
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
This high quality LCD monitor has a toughened safety glass fitted behind the bezel. It offers hardness rating, capable of resisting above normal pressure and impacts to the display. The high end LCD panel with LED backlights not only reduces the power consumption it also offers a bright image with high contrast.
Product Description iiyama ProLite P2252HS-B1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 20.1 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 225 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Screen Coating 8H Hard Coating
Colour Black
Dimensions (WxDxH) 51.65 cm x 19.5 cm x 38.25 cm
Weight 4.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite P2252HS...
£127.71
