iiyama ProLite T1521MSC-B1 15" 1024 x 768 8ms VGA Touch...
£326.24
Delivery:
Standard: 1-3 working days
Key features
  • Touch technology - capacitive
  • IP54
  • Scratch resistance
  • Diagonal Size: 15in
  • Max Resolution: 1024 x 768
  • Response Time: 8ms
  • Speakers: Speaker(s)
  • Interfaces: VGA (HD-15)
Product codes
The ProLite T1521MSC-B1 15" touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability, scratch-resistance and perfect picture performance. A solid and steady base supports the touchscreen with an adjustable stand offering up to 80 degree tilt angles. Menu buttons are located on the back of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the touchscreen for cleaning. The ProLite T1521MSC-B1 is an incredibly powerful touch solution, perfect for instore retail purposes.
Product Description iiyama ProLite T1521MSC-B1 - LED monitor - 15"
Device Type LED-backlit LCD monitor - 15" - touchscreen
Features Touch-screen
Panel Type TN
Aspect Ratio 4:3
Native Resolution 1024 x 768
Pixel Pitch 0.297 mm
Brightness 350 cd/m²
Contrast Ratio 800:1
Response Time 8 ms (black-to-white)
Colour Support 16.2 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 34.05 cm x 19.8 cm x 30.8 cm
Compliant Standards DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1521MS...
£326.24
