We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite T1521MSC-B1 15" touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability, scratch-resistance and perfect picture performance. A solid and steady base supports the touchscreen with an adjustable stand offering up to 80 degree tilt angles. Menu buttons are located on the back of the screen which can be locked to prevent tampering, and includes a handy function to deactivate the touchscreen for cleaning. The ProLite T1521MSC-B1 is an incredibly powerful touch solution, perfect for instore retail purposes.
Product Description | iiyama ProLite T1521MSC-B1 - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Energy Class | Class E | Power Consumption (On mode) | 10.8 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | 1024 x 768 at 75 Hz | Pixel Pitch | 0.297 mm | Brightness | 350 cd/m² | Contrast Ratio | 800:1 | Response Time | 8 ms (black-to-white) | Colour Support | 16.2 million colours | Input Connectors | VGA | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 34.05 cm x 19.8 cm x 30.8 cm | Compliant Standards | DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 305 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 60 kHz |
Horizontal Viewing Angle | +80 / -80 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, sharpness, colour temperature, phase, clock |
OSD Languages | English, German, French, Italian, Polish, Russian, Spanish, Dutch |
Features | HID Compliant, scratch-resistant, a-Si technology |
Colour | Black |
Dimensions (WxDxH) | 34.05 cm x 19.8 cm x 30.8 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , USB , Audio line-in (mini-jack) |
Mechanical | |
Tilt Angle | -10/+70 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x USB cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 10.8 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows Vista / XP / 7 / 8, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 34.05 cm - depth: 4.45 cm - height: 26.8 cm , With stand - width: 34.05 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
