iiyama ProLite T1531SAW-B3 15" 1024 x 768 8ms VGA DVI To...
iiyama ProLite T1531SAW-B3 15" 1024 x 768 8ms VGA DVI Touch Monitor
£389.85
Delivery:
Key features
  • Surface acoustic wave technology
  • Scratch resistance
  • Dust and water resistance
  • Advanced speakers
  • VESA compliance
Product codes
The ProLite T1531SAW uses highly accurate surface acoustic wave touch technology (SAW) with a pure-glass scratch resistive front, offering superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the robust design and solid but flexible stand ensures resilience in demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touch screen for cleaning . The Iiyama Prolite T1531SAW1 touch screen is ideal for a wide range of applications including POS, kiosks, hospitality and entertainment, control rooms, education, training and many others.
iiyama ProLite T1531SAW-B3 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
8H Hard Coating
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1531SA...
£389.85
