We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
ProLite T1531SR-W5 is based on 5 wire resistive touch technology. The price / performance ratio is ideal for the budget conscious user while quality and performance are certainly not compromised. The display inputs include both analogue and digital (HDMI and DisplayPort) with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. The ProLite T1531SR-W5 can be used in a variety of environments, especially recommended for shops, restaurants and industrial purposes. Available in black and white.
Product Description | iiyama ProLite T1531SR-W5 - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 20 kWh | Power Consumption (On mode) | 10.6 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | 1024 x 768 | Pixel Pitch | 0.297 mm | Brightness | 370 cd/m² | Contrast Ratio | 700:1 | Response Time | 8 ms | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50 - 60 Hz) | Colour | White | Image Colour Disclaimer | The displayed product image may be a different colour | Dimensions (WxDxH) | 35.1 cm x 20.1 cm x 30.6 cm | Weight | 4.8 kg | Compliant Standards | Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 300 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 60 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | HDCP, 5-Wire Resistive Touch Screen Technology, integrated cable management |
Colour | White |
Weight | 4.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Resistive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Headphones , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), 80% light transmittance |
Cables Included | 1 x HDMI cable , 1 x audio cable , 1 x USB cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 10.6 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
