iiyama ProLite T1532MSC 15" 1024x768 VGA DVI-D Touch Scr...
iiyama ProLite T1532MSC 15" 1024x768 VGA DVI-D Touch Screen Monitor
Key features
  • IP54
  • Scratch resistance
  • VESA
Product codes
The ProLite T1532MSC 15" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1532MSC-B3X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
350 cd/m²
Contrast Ratio
700:1
Response Time
8 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
VCCI, CB, cULus, IP54, TUV Bauart
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1532MS...
