iiyama ProLite T1532MSC-B3AG 15" 1024x768 8ms VGA DVI To...
iiyama ProLite T1532MSC-B3AG 15" 1024x768 8ms VGA DVI Touch Monitor
£437.42
Delivery:
Key features
  • Capacitive touch technology
  • AG coating
  • IP54 rated
  • Scratch resistance
  • Speakers
Product codes
The ProLite T1532MSC 15" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch-screen with an adjustable stand offering full 90-degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1532MSC-B3AG - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 7H Hard Coating
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
VCCI, CB, cULus, IP54, TUV Bauart, CU
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1532MS...
£437.42
