We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite T1532MSC-B5X multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree positioning angles.
Product Description | iiyama ProLite T1532MSC-B5X - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Energy Class | Class E | Power Consumption (On mode) | 10.2 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | XGA 1024 x 768 at 75 Hz | Pixel Pitch | 0.297 mm | Brightness | 370 cd/m² | Contrast Ratio | 700:1 | Response Time | 8 ms (black-to-white) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 35.1 cm x 20.2 cm x 30.65 cm | Weight | 4.5 kg | Compliant Standards | Plug and Play, VCCI, CB, IP54, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 330 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.47 - 60.02 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | HDCP, edge-to-edge glass, OSD lock, scratch-resistant |
Colour | Black |
Dimensions (WxDxH) | 35.1 cm x 20.2 cm x 30.65 cm - with stand |
Weight | 4.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , USB , Audio line-in (mini-jack) |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Cable cover |
Cables Included | 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 10.2 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 35.1 cm - depth: 20.2 cm - height: 30.65 cm - weight: 4.5 kg , Without stand - width: 35.1 cm - depth: 5.45 cm - height: 27.6 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
