The ProLite T1721MSC-B1 17 inch touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability,
Product Description | iiyama ProLite T1721MSC-B1 - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" - touchscreen | Energy Class | Class F | Power Consumption (On mode) | 14.2 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.264 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 39.25 cm x 19.8 cm x 36.4 cm | Weight | 4.4 kg | Compliant Standards | VESA DPMS, CB, cULus, TUV Bauart, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 80 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Polish, Russian, Spanish, Dutch |
Features | HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology |
Colour | Black |
Weight | 4.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DVI-D , VGA , USB |
Mechanical | |
Tilt Angle | -10/+70 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x USB cable , 1 x DVI cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14.2 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows Vista / XP / 7 / 8, Windows 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
