iiyama ProLite T1721MSC-B1 17" 1280 x 1024 5ms VGA DVI T...
£330.28
Delivery:
Product codes
The ProLite T1721MSC-B1 17 inch touchscreen is based on projected capacitive technology, offering optimal seamless and accurate touch response. Due to its glass overlay, it guarantees high durability,
Product Description iiyama ProLite T1721MSC-B1 - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17" - touchscreen
Features Touch-screen
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) 39.25 cm x 19.8 cm x 36.4 cm
Weight 4.4 kg
Compliant Standards VESA DPMS, CB, cULus, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1721MS...
£330.28
