We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite T1731SAW-B5 offers superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the solid but flexible stand ensures resilience in demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touchscreen for cleaning.
Product Description | iiyama ProLite T1731SAW-B5 - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 22 kWh | Power Consumption (On mode) | 12.3 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.264 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 38.7 cm x 20.1 cm x 34.2 cm | Weight | 5.8 kg | Compliant Standards | Plug and Play, VCCI, GOST, DDC-2B, IP54, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Brightness w/touchscreen | 230 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +85 / -80 |
Vertical Viewing Angle | +85 / -80 |
Backlight Technology | WLED |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP |
Colour | Black |
Weight | 5.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Surface acoustic wave |
Connectivity | |
Interfaces | HDMI , VGA , DisplayPort , USB |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), 92% light transmittance |
Cables Included | 1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12.3 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
