iiyama ProLite T1731SR-B1 17" 1280x1024 5ms VGA DVI Touc...
iiyama ProLite T1731SR-B1 17" 1280x1024 5ms VGA DVI Touchscreen LCD Monitor
Key features
  • Combo serial transfer
  • DVI-I/DVI-D input connector
  • Kensington lock prepared
  • Speakers
  • VESA mounting
Product codes
ProLite T1731SR is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
Iiyama ProLite T1731SR-B1 - LCD monitor - 17"
LCD monitor - 17"
Built-in Devices
Touch-screen , stereo speakers
Panel Type
TN
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
200 cd/m2
Contrast Ratio
900:1
Response Time
5 ms
Colour Support
16.2 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
38.7 cm x 34.2 cm x 20.2 cm
5.7 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1731SR...
