We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
ProLite T1731SR-W5 is based on modern technology. The display inputs include both analog and digital with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand.
Product Description | iiyama ProLite T1731SR-W5 - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 20 kWh | Power Consumption (On mode) | 12.9 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.264 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | White | Dimensions (WxDxH) | 38.7 cm x 20.1 cm x 34.2 cm | Weight | 5.8 kg | Compliant Standards | Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Brightness w/touchscreen | 200 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, scratch-resistant |
Colour | White |
Weight | 5.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Resistive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , USB , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), 80% light transmittance |
Cables Included | USB cable , HDMI cable , Audio cable , DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12.9 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
