iiyama ProLite T1732MSC-B1AG 17" 1280 x 1024 5ms VGA DVI...
iiyama ProLite T1732MSC-B1AG 17" 1280 x 1024 5ms VGA DVI Monitor
£478.35
Delivery:
Key features
  • Touch technology - Capacitive
  • AG coating
  • IP54
  • Scratch resistance
  • Speakers
Product codes
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description iiyama ProLite T1732MSC-B1AG - LCD monitor - 17"
Device Type LCD monitor - 17" - touchscreen
Features Touch-screen
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.264 mm
Brightness 225 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (black-to-white)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 38.7 cm x 20.2 cm x 34.2 cm
Weight 5.6 kg
Compliant Standards VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1732MS...
£478.35
