iiyama ProLite T1732MSC-B5AG 17" 1280x1024 5ms HDMI VGA...
iiyama ProLite T1732MSC-B5AG 17" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
£458.60
Delivery:
Key features
  • Touch technology - Capacitive
  • AG coating
  • IP54
  • Scratch resistance
  • Speakers
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description iiyama ProLite T1732MSC-B5AG - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17" - touchscreen
Energy Class Class B
Energy Consumption per Year 27 kWh
Power Consumption (On mode) 19 W
Features Touch-screen
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Image Colour Disclaimer The displayed product image may be a different colour
Dimensions (WxDxH) - with stand 38.7 cm x 20.2 cm x 34.2 cm
Weight 5.6 kg
Compliant Standards Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1732MS...
£458.60
