iiyama ProLite T1732MSC-W1AG 17" 1280 x 1024 5ms VGA DVI...
iiyama ProLite T1732MSC-W1AG 17" 1280 x 1024 5ms VGA DVI Monitor
Key features
  • Touch technology - capacitive
  • Scratch resistance
  • IP54
  • LED-backlit
Product codes
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1732MSC-W1AG - LCD monitor - 17"
LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
White
38.7 cm x 20.2 cm x 34.2 cm
5.6 kg
VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1732MS...
