iiyama ProLite T1732MSC-W1X 17" 1280x1024 5ms VGA DVI US...
iiyama ProLite T1732MSC-W1X 17" 1280x1024 5ms VGA DVI USB Touchscreen Monitor
£361.70
Delivery:
Key features
  • Touch technology - capacitive
  • Scratch resistance
  • LED-backlit
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree positioning angles. Menu buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the touchscreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description iiyama ProLite T1732MSC-W1X - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17" - touchscreen
Features Touch-screen
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.264 mm
Brightness 225 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour Black, white
Dimensions (WxDxH) 38.7 cm x 20.2 cm x 34.2 cm
Weight 5.6 kg
Environmental Standards TCO Certified
Compliant Standards VCCI, VESA DPMS, CB, GOST-R, IP54, TUV Bauart
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1732MS...
£361.70
