The ProLite T1732MSC-W5AG multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree positioning angles.
Product Description | iiyama ProLite T1732MSC-W5AG - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" - touchscreen | Energy Class | Class B | Energy Consumption per Year | 27 kWh | Power Consumption (On mode) | 19 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.264 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Matt white | Dimensions (WxDxH) - with stand | 38.7 cm x 20.2 cm x 34.2 cm | Weight | 5.6 kg | Compliant Standards | Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, Advanced Frame Rate Control (AFRC), glove touch mode |
Dimensions (WxDxH) | 38.7 cm x 20.2 cm x 34.2 cm - with stand |
Weight | 5.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , USB , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Cable cover |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
