iiyama ProLite T1932MSC-B2X 17" 1280x1024 5ms VGA DVI US...
iiyama ProLite T1932MSC-B2X 17" 1280x1024 5ms VGA DVI USB Touchscreen Monitor
£506.38
Delivery:
Product codes
The ProLite T1932MSC-B2X 19" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
iiyama ProLite T1932MSC-B2X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
43.2 cm x 21.9 cm x 39.1 cm
6.9 kg
VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1932MS...
£506.38
