The ProLite T1932MSC-B5AG 19" multitouch screen is based on projective capacitive technology, which guarantees high durability, scratch resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. Anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90-degree positioning angles. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description | iiyama ProLite T1932MSC-B5AG - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 14.2 W | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.2928 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 14 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 43.2 cm x 21.9 cm x 39.1 cm | Weight | 6.9 kg | Compliant Standards | VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, edge-to-edge glass, scratch-resistant |
Colour | Black |
Weight | 6.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Audio line-in , USB |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), IP54 protection, 85% light transmittance |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable , 1 x audio cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14.2 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption (Off Mode) | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
