iiyama ProLite T1932MSC-B5AG 19" 1280x1024 14ms VGA HDMI...
iiyama ProLite T1932MSC-B5AG 19" 1280x1024 14ms VGA HDMI DisplayPort IPS LED Monitor
£512.92
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology
  • Capacitive touch technology
  • Scratch resistance
  • Anti-glare coating
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite T1932MSC-B5AG 19" multitouch screen is based on projective capacitive technology, which guarantees high durability, scratch resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. Anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90-degree positioning angles. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description iiyama ProLite T1932MSC-B5AG - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19" - touchscreen
Energy Class Class E
Energy Consumption per Year 33 kWh
Power Consumption (On mode) 14.2 W
Features Touch-screen
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Pixel Pitch 0.2928 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 14 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 43.2 cm x 21.9 cm x 39.1 cm
Weight 6.9 kg
Compliant Standards VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£512.92
