iiyama ProLite T1932MSC-B5X 19" 1280x1024 14ms HMDI VGA...
iiyama ProLite T1932MSC-B5X 19" 1280x1024 14ms HMDI VGA DP LED Monitor
£499.29
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ProLite T1932MSC-B2X multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
Product Description iiyama ProLite T1932MSC-B5X - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19" - touchscreen
Energy Class Class B
Features Touch-screen
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.2928 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 14 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 43.2 cm x 21.9 cm x 39.1 cm
Weight 6.9 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, DDC-2B, CB, cULus, IP54, TUV Bauart, EAC, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T1932MS...
£499.29
