iiyama ProLite T1932MSC-W2AG 19" 1280 x 1024 14ms VGA DV...
iiyama ProLite T1932MSC-W2AG 19" 1280 x 1024 14ms VGA DVI Monitor
Key features
  • Touch technology - capacitive
  • IP54
  • Scratch resistance
  • AG Coating
Product codes
The ProLite T1932MSC-W2AG 19" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description iiyama ProLite T1932MSC-W2AG - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19" - touchscreen
Features Touch-screen
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour White
Dimensions (WxDxH) - with stand 43.2 cm x 21.9 cm x 39.1 cm
Weight 6.9 kg
Compliant Standards VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
