The ProLite T1932MSC-W2AG 19" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch screen with an adjustable stand offering full 90 degree positioning angles. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description | iiyama ProLite T1932MSC-W2AG - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" - touchscreen | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Colour | White | Dimensions (WxDxH) - with stand | 43.2 cm x 21.9 cm x 39.1 cm | Weight | 6.9 kg | Compliant Standards | VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | Edge-to-edge glass, scratch-resistant |
Colour | White |
Dimensions (WxDxH) | 43.2 cm x 21.9 cm x 39.1 cm - with stand |
Weight | 6.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , DVI-D , USB , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
