We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProLite T1932MSC-W5AG multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
Product Description | iiyama ProLite T1932MSC-W5AG - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 14.2 W | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.2928 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 14 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | White | Image Colour Disclaimer | The displayed product image may be a different colour | Dimensions (WxDxH) | 43.2 cm x 21.9 cm x 39.1 cm | Weight | 6.9 kg | Compliant Standards | VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, edge-to-edge glass, scratch-resistant |
Colour | White |
Weight | 6.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Audio line-in , USB |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), IP54 protection, 85% light transmittance |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable , 1 x audio cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14.2 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption (Off Mode) | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
