We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Connect and go with the ProLite T2234AS-B1, the all-in-one monitor solution for shops, retail or information desks. This 21.5" PCAP 10-point touchscreen with Android allows users to directly connect and operate the monitor from any device. The HDMI output makes it easy to connect a second customer-facing display for dynamic content and advertising.
The robust screen comes with a rugged bezel and an IP65 rating, meaning the monitor is dust and water resistant from the front. Cables can be neatly tied with the special cable cover, so they cannot come loose or move around. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect interactive display for instore retail.
Product Description | iiyama ProLite T2234AS-B1 - kiosk RK3288 1.8 GHz - 2 GB - SSD 16 GB - LED 21.5" | Type | Kiosk - kiosk | Processor | 1 x Rockchip RK3288 / 1.8 GHz (Quad-Core) | RAM | 2 GB LPDDR3 SDRAM | Hard Drive | SSD 16 GB - eMMC | Optical Storage | No optical drive | Monitor | 21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen | Graphics Controller | ARM Mali-T760 MP4 | Audio Output | Stereo | Networking | GigE, 802.11a, RS-232C, 802.11b/g/n, Bluetooth 4.0 | Power | AC 120/230 V (50/60 Hz) | OS Provided | Android 8.1 (Oreo) | Colour | Black | Dimensions (WxDxH) | 51.75 cm x 35.15 cm x 21.9 cm | Weight | 6.6 kg | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | Kiosk |
Product Form Factor | Kiosk |
Built-in Devices | Speaker, capacitive touch screen |
Colour | Black |
Processor / Chipset | |
CPU | Rockchip RK3288 |
Clock Speed | 1.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
RAM | |
Installed Size | 2 GB |
Technology | LPDDR3 SDRAM |
Hard Drive | |
Type | SSD - eMMC |
Capacity | 1 x 16 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | LED - IPS |
Touchscreen | Yes (10-point multi-touch) |
Diagonal Size | 21.5" |
Native Resolution | 1920 x 1080 (Full HD) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Pixel Pitch | 0.247 mm |
Response Time | 8 ms |
Image Brightness | 350 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Cable management cover, HDCP, Projected Capacitive Touch (PCT) technology, Hard Coating (7H) |
Graphics Controller | |
Graphics Processor | ARM Mali-T760 MP4 |
Audio Output | |
Sound Output Mode | Stereo |
Input Device | |
Type | Touch-screen |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, RS-232C, IEEE 802.11n, Bluetooth 4.0 |
Expansion / Connectivity | |
Interfaces | 2 x USB 2.0 (OTG) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HDMI , 1 x serial |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | Plug and Play, DDC-2B, CCC, cULus, CU, REACH SvHC, IP65 front |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 25 Watt |
Power Consumption Stand by | 0.5 Watt |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 51.75 cm |
Depth | 35.15 cm |
Height | 21.9 cm |
Weight | 6.6 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
