With 1920 x 1080 Full HD resolution and Projective Capacitive 10 point touch technology, the ProLite T2235MSC delivers seamless and accurate touch response. Featuring VA LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand allowing the monitor to lay down completely flat for use as a giant tablet. The T2235MSC comes equipped with several video inputs and stereo speakers delivering good quality sound. An ideal screen for Interactive Digital Signage, InStore Retail, Gaming and Interactive Presentations purposes.
Product Description | iiyama ProLite T2235MSC-B1 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class F | Power Consumption (On mode) | 17.2 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 52.25 cm x 4.9 cm x 32.05 cm | Weight | 5 kg | Compliant Standards | DDC-2B, VESA DPMS, TUV Bauart, VCCI Class B, CU-EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | VA |
Brightness w/touchscreen | 225 cd/m² |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 176 |
Vertical Viewing Angle | 176 |
Backlight Technology | LED backlight |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, blue reduction |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | Eco-Mode, X-Res Technology, 10-point multi-touch |
Colour | Black |
Weight | 5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touchscreen |
Connectivity | |
Interfaces | VGA , DVI-D , DisplayPort , USB , Audio line-in |
Mechanical | |
Tilt Angle | -15/+70 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x audio cable , 1 x DVI cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.2 kWh/1000h |
Power Consumption (Typical) | 21 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows Vista / 7 / 8, Windows 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
