With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2236MSC is the ideal screen for a great touch-experience.
Product Description | iiyama ProLite T2236MSC-B2 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class F | Energy Consumption per Year | 34 kWh | Power Consumption (On mode) | 18.5 W | Features | Touch-screen, USB 3.0 hub | Panel Type | A-MVA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 52.25 cm x 25.4 cm x 36.7 cm | Weight | 5.8 kg | Compliant Standards | DDC-2B, VESA DPMS, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 3.0 hub |
Brightness w/touchscreen | 213 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, contrast, H/V position, input select, colour temperature, phase, aspect control, blue reduction |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese |
Features | Eco-Mode, Advanced Contrast Ratio (ACR), 10-point multi-touch, blue light reduction |
Colour | Black |
Dimensions (WxDxH) | 52.25 cm x 25.4 cm x 36.7 cm - with stand |
Weight | 5.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Headphones , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable - USB Type A to B |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.5 kWh/1000h |
Power Consumption (Typical) | 23 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | No |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows 7 / Windows 8 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 52.25 cm - depth: 25.4 cm - height: 36.7 cm - weight: 5.8 kg , Without stand - width: 52.25 cm - depth: 5.7 cm - height: 31.6 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
