iiyama ProLite T2236MSC-B2 LED 22" t/screen 1920x 1080...
£303.37
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Touch technology - capacitive
  • AMVA
  • Scratch resistance
  • Blue light reducer
  • Speakers
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 8ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2236MSC is the ideal screen for a great touch-experience.
Product Description iiyama ProLite T2236MSC-B2 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22" - touchscreen
Energy Class Class B
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Features Touch-screen, USB 3.0 hub
Panel Type A-MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 12000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 52.25 cm x 25.4 cm x 36.7 cm
Weight 5.8 kg
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T2236MS...
£303.37
