iiyama ProLite T2236MSC-B2AG 21.5" 1920x1080 8ms VGA DVI...
£342.50
16 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • AMVA technology
  • Touch technology - capacitive
  • AG coating
  • Scratch resistance
  • High-quality stereo speakers
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 8ms
  • Speakers: Speaker(s)
  • Interfaces: VGA (HD-15), DVI, HDMI
Product codes
With its Full HD resolution and accurate Projective Capacitive 10-point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience.
Product Description iiyama ProLite T2236MSC-B2AG - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5" - touchscreen
Energy Class Class F
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 18.5 W
Features Touch-screen, USB 3.0 hub
Panel Type A-MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 12000000:1 (dynamic)
Response Time 8 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare, 7H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 52.25 cm x 36.7 cm x 25.4 cm
Weight 5.8 kg
Compliant Standards DDC-2B, VESA DPMS, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
iiyama ProLite T2236MSC-B2AG 21.5" 1920x1080 8ms VGA DVI HDMI Monit
£342.50
