iiyama ProLite T2252MSC-B1 21.5" 1920x1080 7ms VGA HDMI...
£259.35
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Touch technology - capacitive
  • IPS technology
  • Scratch resistance
  • Blue light reducer
  • VESA
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 7ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, VGA (HD-15), HDMI
Product codes
With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2252MSC-B1 delivers seamless and accurate touch response. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect choice for a vast array of interactive applications. The flexible stand can be positioned at several angels creating a comfortable and ergonomic user experience. In addition, the edge-to-edge glass and ultra slim design creates an eye-catching finish. The ProLite T2252MSC-B1 is the ideal solution for interactive signage, instore retail, POS and interactive presentations.
Product Description iiyama ProLite T2252MSC-B1 - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22" - touchscreen
Energy Class Class F
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 17.8 W
Features Touch-screen
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 49.05 cm x 22.05 cm x 37.05 cm
Weight 2.16 kg
Compliant Standards DDC-2B, VESA DPMS, cULus, TUV Bauart, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
iiyama ProLite T2252MSC-B1 21.5" 1920x1080 7ms VGA HDMI DP Monitor
£259.35
