iiyama ProLite T2336MSC-B2 23" 1920x1080 5ms VGA DVI HDM...
£331.59
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Touch technology - capacitive
  • Scratch resistance
  • OverDrive ON/OFF
  • Blue light reducer
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
With its Full HD (1920 x 1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2336MSC delivers seamless and accurate touch response. The IPS panel technology guarantees high performance with exceptional color reproduction and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles, creating a comfortable and ergonomic user experience.
Product Description iiyama ProLite T2336MSC-B2 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23" - touchscreen
Energy Class Class B
Energy Consumption per Year 37 kWh
Power Consumption (On mode) 25.3 W
Features Touch-screen, USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2652 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 7H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 56.1 cm x 25.4 cm x 37.9 cm
Weight 6.3 kg
Compliant Standards VCCI, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
iiyama ProLite T2336MSC-B2 23" 1920x1080 5ms VGA DVI HDMI Monitor
£331.59
