iiyama ProLite T2453MTS-B1 24" 1920x1080 4ms HDMI DVI VG...
iiyama ProLite T2453MTS-B1 24" 1920x1080 4ms HDMI DVI VGA LED Monitors
£248.16
16 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The ProLite T2453MTS-B1 is based on optical touch technology with a pure-glass scratch resistive front, offering superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for several applications.
Product Description iiyama ProLite T2453MTS-B1 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24" - touchscreen
Energy Class Class A
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Features Touch-screen, stylus, USB 2.0 hub
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.272 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 120000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 51.7 cm x 22.05 cm x 38.75 cm
Weight 6 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, DDC-2B, CB, TUV Bauart, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite T2453MT...
£248.16
