General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Energy Consumption per Year |
34 kWh |
Power Consumption (On mode) |
23 W |
Diagonal Size |
24" |
Viewable Size |
23.6" |
Built-in Devices |
USB 2.0 hub |
Panel Type |
VA |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.272 mm |
Brightness |
250 cd/m² |
Brightness w/touchscreen |
220 cd/m² |
Contrast Ratio |
3000:1 / 120000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
4 ms |
Vertical Refresh Rate |
55 - 75 Hz |
Horizontal Refresh Rate |
30 - 80 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
LED backlight |
OSD Languages |
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features |
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction |
Colour |
Black |
Dimensions (WxDxH) |
51.7 cm x 22.05 cm x 38.75 cm |
Weight |
6 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Input |
Type |
Touch-screen, stylus - touchscreen |
Movement Detection Technology |
Optical |
Connectivity |
Interfaces |
VGA , DVI , HDMI , Headphones , USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B) |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
-3/+73 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), 88% light transmittance |
Cables Included |
1 x HDMI cable , 1 x SuperSpeed USB cable |
Compliant Standards |
Plug and Play, DDC-2B, CB, TUV Bauart, EAC |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
18 Watt |
Power Consumption Stand by |
0.5 Watt |
Environmental Standards |
ENERGY STAR Certified |
Yes |
