With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2454MSC-B1AG delivers seamless and accurate touch response. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect choice for a vast array of interactive applications. The Anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2454MSC-B1AG is the ideal solution for interactive signage, instore retail, POS and interactive presentations.
Product Description | iiyama ProLite T2454MSC-B1AG - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" - touchscreen | Energy Class | Class F | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 20 W | Features | Touch-screen, stylus, USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.274 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Height, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 54.05 cm x 12.8 cm x 38.8 cm | Weight | 5.5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, DDC-2B, CB, RoHS, WEEE, REACH, TUV Bauart, ERP, VCCI Class B, EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | HDCP, Eco-Mode, anti-glare, Advanced Contrast Ratio (ACR), i-Style Color, ultra-thin bezel design |
Weight | 5.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen, stylus - touchscreen |
Movement Detection Technology | Capacitive |
Connectivity | |
Interfaces | VGA , HDMI , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in (mini-jack) , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | -5/+90 |
Height Adjustment | 70 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m |
MTBF | 30,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
