General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class B |
Diagonal Size |
27" |
Viewable Size |
27" |
Built-in Devices |
Microphone, camera, USB 3.0 hub |
Panel Type |
A-MVA+ |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 |
Pixel Pitch |
0.311 mm |
Brightness |
255 cd/m² |
Brightness w/touchscreen |
220 cd/m² |
Contrast Ratio |
3000:1 / 12000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
12 ms (typical); 5 ms (grey-to-grey) |
Vertical Refresh Rate |
55 - 75 Hz |
Horizontal Refresh Rate |
24 - 80 kHz |
Horizontal Viewing Angle |
+89 / -89 |
Vertical Viewing Angle |
+89 / -89 |
Screen Coating |
7H Hard Coating |
Backlight Technology |
LED backlight |
Controls & Adjustments |
Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock, blue reduction |
OSD Languages |
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese |
Features |
Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, 10-point multi-touch, blue light reduction |
Colour |
Black |
Dimensions (WxDxH) |
67.25 cm x 5 cm x 41.9 cm |
Weight |
8.2 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Input |
Type |
Touch-screen |
Movement Detection Technology |
Projected capacitive |
Connectivity |
Interfaces |
VGA , DVI-D , MHL / HDMI , Headphones , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
+15/+70 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), built-in adjustable tilt stand |
Cables Included |
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable |
Compliant Standards |
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 100/240 V (50/60 Hz) |
Power Consumption Operational |
36 Watt |
Power Consumption Stand by |
0.5 Watt |
Software / System Requirements |
Included Software |
Driver |
OS Required |
Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8 |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
