iiyama ProLite TF1534MC-B1X 15" 1024 x 768 8ms VGA DVI...
iiyama ProLite TF1534MC-B1X  15" 1024 x 768 8ms VGA DVI Monitor
Key features
  • Capacitive touch technology
  • Open frame
  • Scratch-resistance
  • LED-backlit monitor
Product codes
The ProLite TF1534MC 15" multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The higher brightness ensures crispy and clear image, resulting in outstanding information transmission performance, even in bright environment. The touch function remains unaffected even if the glass is scratched. The screen is dust- and water-resistant.
iiyama ProLite TF1534MC-B1X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.264 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
33.75 cm x 4.45 cm x 26.55 cm
2.7 kg
DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, IP65
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF1534M...
