The ProLite TF1534MC-B6X 15" multitouch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant from the front. For ease of installation in any environment the ProLite TF1534MC-B6X comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
Product Description | iiyama ProLite TF1534MC-B6X - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Energy Class | Class E | Power Consumption (On mode) | 10.8 W | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | 1024 x 768 at 75 Hz | Pixel Pitch | 0.297 mm | Brightness | 370 cd/m² | Contrast Ratio | 700:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Colour | Black, matte | Dimensions (WxDxH) | 33.75 cm x 4.45 cm x 26.55 cm | Weight | 2.7 kg | Compliant Standards | Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, EAC, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 330 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 60 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode |
Weight | 2.7 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DisplayPort , VGA , USB , HDMI |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | 90% light transmittance |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m |
Mounting Kit | Included |
Power | |
Power Consumption SDR (On mode) | 10.8 kWh/1000h |
Power Consumption (Typical) | 9 Watt |
Power Consumption Stand by | 2 Watt |
Power Consumption (Off Mode) | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Linux, Microsoft Windows |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
