iiyama ProLite TF1734MC-B1X 17" 1280x1024 5ms VGA DVI US...
iiyama ProLite TF1734MC-B1X 17" 1280x1024 5ms VGA DVI USB Touchscreen LED Monitor
Key features
  • Touch technology - capacitive
  • Open frame
  • Scratch resistance
  • LED-backlit
Product codes
The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
iiyama ProLite TF1734MC-B1X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
36.9 cm x 4.75 cm x 30.7 cm
3.6 kg
VESA DPMS, CB, IP54, TUV Bauart
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF1734M...
