iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA D...
iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
£451.06
Delivery:
Standard: 1-3 working days
Key features
  • Touch technology - capacitive
  • Open frame brackets
  • IP code
  • Scratch resistance
  • LED backlit
Product codes
The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and instore retail.
iiyama ProLite TF1734MC-B5X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, matte
36.9 cm x 4.75 cm x 30.7 cm
3.6 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF1734M...
£451.06
