iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA D...
iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
Key features
  • Touch technology - capacitive
  • Open frame brackets
  • IP code
  • Scratch resistance
  • LED backlit
Product codes
The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and instore retail.
Product Description iiyama ProLite TF1734MC-B5X - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17" - touchscreen
Features Touch-screen
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Colour Black, matte
Dimensions (WxDxH) 36.9 cm x 4.75 cm x 30.7 cm
Weight 3.6 kg
Compliant Standards Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
iiyama ProLite TF1734M...
